Boot via Lan
Hello, everyone!
I have this problem with my laptop (a HP Pavilion dv1000) and I can't figure out what to do. I had to format it and everything was normal until I tried to re-install Windows XP. I boot from the CD (actually a DVD-writer) and start everything as it should be, until setup reaches a certain point where it starts to say it simply can't copy a file. I tell it to retry but it keeps saying it can't do it. The only choice I have then is to skip that file. Problem #1: it says the same thing for like 10 or 20 files. Sometimes, different files, but everytime I install I get the same problem.
Anyway, a friend told me this could be a problem with my DVD drive. Since my laptop does not come with a floppy disk drive nor allows me to boot from a USB port, my question is: how do I make it boot from my LAN? It gives me the option, but when I do it it says it can't find anything and asks me to restart the computer. What do I have to do to actually make it boot via LAN and, after that, install WinXP using another machine?
Thanks for any info!
Net boot is generally for large companies that want to do a standardized unattended install on a lot of PCs - the setup takes work, the payoff is in using it more than once. You might need a Windows 2003 server and some additional setup. I've never tried this in Windows, only Linux. This might help: http://technet2.microsoft.com/WindowsServer/en/Library/17926e97-8038-4a20-beb0-f50298fd107c1033.mspx
But you're probably better off (in financial and sanity terms) with an out-of-warranty HP repair.
I'm just doing cost/benefit here - is it better to use $300 or your or your staff's time, or pay somebody $200 (and have the working drive to boot)? Or, I don't know the DV1000, but is the drive user-replaceable? Because you can get it on Ebay for maybe $100.
But, one question - are you sure it's the drive? Did you try it with a different CD? This sounds counterintuitive, but sometimes you can fix these problems by using another computer to copy the CD nd using the copy to install.
Done that...with 3 different copies (all original ones). Same problem. Isn't there a way to create a boot cd with, let's say, autoexec and config, just enough for me to have access to command line and then make it part of my network? I could use another computer's cd drive, I guess.
Rick,
how did you format? I had a problem with w2k like you are having quite some time ago. I had to do a format in dos. and had to use this link I believe to create a boot cd/ for dos.
http://www.pcworld.idg.com.au/index.php/id;1701252989;fp;1024;fpid;
http://www.nu2.nu/bootcd/
takes a little reading to understand how to set it up. I know that I burned a few cd's before I actually got it working right.
MIke
