anti-aliasing Vray light material
Crazy Homeless Guy
is this a problem for anyone else? whenever i use a Vray light material, the anti-aliasing around the edge of the material... well, it does not seem like there is any. technically, i should be creating a separate globe with an object inside that casts light, but the rendering time for the globe often does not fit in my schedule.
This happens if you are working with LWF and thus
disabled the "Clamp output". You could change the
colormapping to a different setting then "Linear multiply"
or "Gamma correction", then it's gone.
Hope this will help ya. ;o)
edit: It's caused through the high intensity, u can do a
test yourself, just create a sphere assign a lightmat and
next to it create a VrayLight (sphere) then crank the
intensity down ... etc.
take care
Oleg
  • 2 years later...
  • 1 year later...
