(z=0)
I have a colleague who uses to pass me the cad files done with ADT 2006, but he only uses wall, doors and windows of the mentioned program.
Of course, when I go to an isometric vue it is a real mess and I can't
model in Sketchup!
Is there a way to get that file totally flat, like a regular Autocad file (Z=0)
Thank you!
  alikashan said:
well i dont know it helps you or not but i think you can export top view in wmf format and then use command line wmfin to brought back it in the acad and then its a flat2d drawing just erase the xtra lines you dont need.:cool:
wmf works but hidden line projection is in built feature of ADT and works pretty well.
if you have autocad and express-tools installed, type: "flatten" this will do the trick.
there is another trick, but it doesn't always work, especially with blocks, so you have to explode them first. then move everything to 0,0,1e99 and then back to 0,0,-1e99 everthing should be flat.
