Elliot Posted May 30, 2006 Share Posted May 30, 2006 I am looking for some operating room doctors and nurses fully dressed with the sterile gowns. I want these models to be inserted on an 3D OR we have created. Any ideas....? Thanks Elliot Link to comment Share on other sites More sharing options...
AJLynn Posted May 30, 2006 Share Posted May 30, 2006 Closest thing I've seen: http://cgarchitect.vismasters.com/catalog/viewproduct.aspx?product=505 There's also a Dosch CD of 3D people at work that has a doctor and a nurse but they don't look so great. Link to comment Share on other sites More sharing options...
Elliot Posted May 30, 2006 Author Share Posted May 30, 2006 Andrew Thanks for the information. I already have a few from RPC. What I need now is some doctors and nurses fully dressed for an operation. We have already made some of this models but they don't look good. I am attaching a real live photo of what I need. Thanks Elliot Link to comment Share on other sites More sharing options...
Ernest Burden III Posted May 30, 2006 Share Posted May 30, 2006 I should ask Jeff to install a button for me to post an answer of http://www.formfonts.com they have some good low-poly models of doctors and nurses. Whomeve it is who makes their people has a great eye for figures. See if these get you started--you would have to add the masks and headcoverings. Link to comment Share on other sites More sharing options...
Elliot Posted May 30, 2006 Author Share Posted May 30, 2006 Ernest, Sometime ago you had recommended this site to me. I subscribed and I had taken some models from it. It is very good. Thanks for the ideas. Elliot Link to comment Share on other sites More sharing options...
William Alexander Posted May 31, 2006 Share Posted May 31, 2006 Something like this might work? Link to comment Share on other sites More sharing options...
Trevor Tizard Posted May 31, 2006 Share Posted May 31, 2006 WDA, Did you use a plug-in for photoshop to get such a clean cut-out or just patience? Thanks. Link to comment Share on other sites More sharing options...
bigroo Posted May 31, 2006 Share Posted May 31, 2006 Trevor Tizard said: WDA, Did you use a plug-in for photoshop to get such a clean cut-out or just patience? Thanks. Don't you mean patients Link to comment Share on other sites More sharing options...
Trevor Tizard Posted May 31, 2006 Share Posted May 31, 2006 Nice...................! Link to comment Share on other sites More sharing options...
Elliot Posted May 31, 2006 Author Share Posted May 31, 2006 William That is very nice. You are very good with Photoshop and that Alpha channel. Question.... I am trying to place these people inside the the 3D Max model instead of placing them as a Photoshop post processing. How would you do that....? Thanks Elliot Link to comment Share on other sites More sharing options...
William Alexander Posted May 31, 2006 Share Posted May 31, 2006 Trevor, Nope no Photoshop Plugin. It's closer to 'rotoscoping', the technique used. Some Path work and painting on a mask. The RGB colors in the image made using channels to extract or even get a good start on a decent mask impossible or at least I could not see the 'Math' to get it done. Add-Subtract, divide.....channels. 'Clean' is actually an eyeball and paint out artifacts that show against different colored backgrounds method...though still it took about 15 minutes. Elliot I think the hardest part of using just any image is matching the 3D scene's camera to the camera of an image like this. Though looking at the image, the camera hieght is that of a man apx 6' tall about 6-8' away (given the size of an opperating room) 40-55 degree field of view, incline (target about 20' away-3.5' off the ground). That would match, best guess, a scene camera to the prepared image. You can take that full image use a plane (Billboard) that matches it's aspect ratio and apply the image as a texture, then use the alpha for an opacity mask to remove everything but the surgical people. That's the easiest way. The over the top way and LOL not so easy is modeling from a camera projection (camera mapping or Image modeling) to match the subject/s. Bake the texture to the matching geometry....then in photoshop use the existing pixel information to fill in where the camera doesn't 'project'....3D version that does not need to be 'camera' matched. To be quite honest, if this is something you'd regularly need for your work it might be worth 'rolling' your own or having someone roll them for you. You got the camera equipment, access to medical personel & facilities.... something to think about. If it's good enough LOL Retial the goods and make some pocket change. WDA Link to comment Share on other sites More sharing options...
Elliot Posted June 1, 2006 Author Share Posted June 1, 2006 William, I sent a message to you. I am not to sure I can follow your instructions...... I am getting older.... he he he Thanks Elliot Link to comment Share on other sites More sharing options...
