tanni Posted May 30, 2006 Share Posted May 30, 2006 I was working with a animation project, where i want to use GI rendering, but I am facing a problem, that there have some un wnted light in my scne, any body can tell how can i solve that problem. There have no gap in betwen window and wall but and wall to wall- but it seems light come from a gap. Tanni Link to comment Share on other sites More sharing options...
mibs_studio Posted May 30, 2006 Share Posted May 30, 2006 Maybe your irridiance map is not high enough..... Also you can burn all the wall floor material, and touchup the map in photoshop to remove the "leaking". Link to comment Share on other sites More sharing options...
Sketchrender Posted May 30, 2006 Share Posted May 30, 2006 Probably not what you want to hear but best to Remodel it, in these situations I find. Phil Link to comment Share on other sites More sharing options...
bigroo Posted May 30, 2006 Share Posted May 30, 2006 Are you using a Vray light plane? If so, it may be touching your window or wall. Link to comment Share on other sites More sharing options...
gadzooks Posted May 30, 2006 Share Posted May 30, 2006 Also try checking the "check sample visibality" in render settings Link to comment Share on other sites More sharing options...
BrianKitts Posted May 30, 2006 Share Posted May 30, 2006 Maybe your irridiance map is not high enough..... that was my first guess, it looks like your irr settings are too low, turn them up to medium and it should clean that up Link to comment Share on other sites More sharing options...
tanni Posted May 31, 2006 Author Share Posted May 31, 2006 Probably not what you want to hear but best to Remodel it, in these situations I find. Phil Thanks all for your Cooperation. The model was draw in autocad 2000. so I am going to remodel it, & one of my team member also agree with that. Tanni Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 31, 2006 Share Posted May 31, 2006 Check that you don't have any GI Blur Link to comment Share on other sites More sharing options...
aligrafix Posted May 31, 2006 Share Posted May 31, 2006 I have gone through the Christropher Nich's DVDs. In his DVD, he was mentioning the same problem like light leekage. He simply baked those textures, "Renhder to texture" then painted on them in photoshop to get rid of that. You have to bake them. Sometimes i also get this problem but this is the way i get rid of this. Link to comment Share on other sites More sharing options...
aligrafix Posted May 31, 2006 Share Posted May 31, 2006 I have gone through the Christropher Nich's DVDs. In his DVD, he was mentioning the same problem like light leekage. He simply baked those textures, "Renhder to texture" then painted on them in photoshop to get rid of that. You have to bake them. Sometimes i also get this problem but this is the way i get rid of this. But till yet, i didnt get solution of my 1 problem. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted May 31, 2006 Share Posted May 31, 2006 Yeah... the reason it happens with Render to textures is that it is mainly due to textures resolution. Normally, with correct modeling it should not happen in a camera render unless you have some funky GI blur setting, or your check visibility is not working. Link to comment Share on other sites More sharing options...
aligrafix Posted May 31, 2006 Share Posted May 31, 2006 Christropher, can you reply to my thread? what is the problem with me with that scene. you have seen the attachments. kindly help please! Link to comment Share on other sites More sharing options...
