geardaddy1 Posted May 30, 2006 Share Posted May 30, 2006 Can anyone take a look at this rendering and see what I can do to get some detail into my textures? Rendering in Max 8 with Vray...Have the settings on high and I am still getting way to much noise. Thanks in advance. Link to comment Share on other sites More sharing options...
Brian Smith Posted May 30, 2006 Share Posted May 30, 2006 What do you mean you have settings on high? What settings? Link to comment Share on other sites More sharing options...
geardaddy1 Posted May 30, 2006 Author Share Posted May 30, 2006 Irradiance map set to high, I haven't really got into the custom settings yet...is that what I need to be doing? Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted May 30, 2006 Share Posted May 30, 2006 We have a VRay section in the forum. Your thread will be much more visible there. Link to comment Share on other sites More sharing options...
mibs_studio Posted May 31, 2006 Share Posted May 31, 2006 Irradiance map set to high, I haven't really got into the custom settings yet...is that what I need to be doing? If that so, it must be you shadow subdiv in vray light, i assume you have put vray light in the scene right? instead of 8 subdiv in the shadow, increase it up to 16 or 32 or between or higher... Link to comment Share on other sites More sharing options...
geardaddy1 Posted May 31, 2006 Author Share Posted May 31, 2006 thanks for the help! I will try that.....Sounds like Rendering time will higher! Link to comment Share on other sites More sharing options...
ShaunDon Posted May 31, 2006 Share Posted May 31, 2006 Can anyone take a look at this rendering and see what I can do to get some detail into my textures? Don't know if you're aware of this, but V-Ray blurs texture maps more than the scanline renderer, so you need to change the blur setting of your maps from 1.0 to 0.1 or even 0.01 (especially for bump maps). This should make your maps render a lot more crisp. Shaun Link to comment Share on other sites More sharing options...
geardaddy1 Posted May 31, 2006 Author Share Posted May 31, 2006 Thanks Shaun. that is what I needed. Thanks again for the help. Link to comment Share on other sites More sharing options...
