curve walls in max
annalea
hi everyone!!!
how can i make curve walls in max? and how do i redefine the color of a material?i really dont have any idead about max. im just point and click on all the buttons. im getting impatient with the tutorial.:confused:
thanks
The post above is quite correct but in this case you will find that you are not gonna have any thickness to your wall.
I would draw the curve in a spline. - I would then go into the spline modify and into outline. If you pull this line out by say 300mm then you have a shape which is suitable for extrusion.
You can also draw a poly line in Autocad - then import the poly line into max and extrude the polyline.
Hope this helps.
hi everyone!!!
thanks
The major 3D applications all have a steep learning curve. If you are getting impatient at this stage, I reckon you'll give up shortly as it's a long road.
I personally loved every step of the way as I was almost obsessed and that helps a lot.
