Justin Hunt Posted June 2, 2006 Share Posted June 2, 2006 I have a problem When obects are set to be invisible to the camera, they still render when an opacity mapped object overlaps or is in front of it, ie I am looking through the transparant object I can still see the invisile object, outside the transparant object renders correctly. In the tree example, the trees with red trunks are 3D Foliage objects that are set not to be seen by the camera and the real looking trees are Plane obects with a opacity mapped tree bitmap. The 3D trees are rendered within the 2D planes and invisible outside the planes. In the Glass roof example, there is a cylender surronding the scene with a Cityscape mapped onto it and set to be invisible to camera, yet it is visible through the glass roof. How do I get these to work? I am rendering with MentalRay JHV Link to comment Share on other sites More sharing options...
abicalho Posted June 2, 2006 Share Posted June 2, 2006 You need to make them invisible to reflections. That will stop them from rendering. Opacity Maps are reflections/refractions with no Index of Refraction from the renderer's point of view. Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 2, 2006 Author Share Posted June 2, 2006 Isn't that a little pointless, the whole reason for the cylender being there is for the reflections. Link to comment Share on other sites More sharing options...
nisus Posted June 27, 2006 Share Posted June 27, 2006 Visible to camera is not the same as visible to reflections ,-) Turn both off nisus Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 27, 2006 Author Share Posted June 27, 2006 You are completly missing the point. I want the reflections but I dont want to see the object anywhere else. Not in the backround, not through transparent objects ONLY in the reflections. It is possible with scanline, just not Mentalray. JHV Link to comment Share on other sites More sharing options...
nisus Posted June 28, 2006 Share Posted June 28, 2006 Hi Justin, So basicly, you only uncheck the 'visible to camera'. And at this time your problem occurs. But why do you have 3d-trees behind Xtrees? What RTdepth are you using? Turn that up? rgds, nisus Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 28, 2006 Author Share Posted June 28, 2006 The "visible trees is just an image mapped onto a plane facing the camera. Due to the angle of the sun to the camera and trees these would only cast a thin shadow. To get proper shadows I used the 3D trees. The 3D trees look ugly but cast nice shadows. This is just one application, there are others These examples explain the issue better JHV Link to comment Share on other sites More sharing options...
nisus Posted June 29, 2006 Share Posted June 29, 2006 Hi Justin, The problem is because when you look through the opacity mapped plane, there is (still) a refraction with IOR 1. As you can see in your example with the knots, you will need to turn off visible to refl/refract too. This off course will not make the objects show up in the reflection... (so I do get the problem) The workaround could be like this: - with a raytrace material, I think you can control refract and refrect seperately. This can help you imho. - for the trees: use the MR facade-shader (although I cannot get it to work properly, so if you can, pls tell me!) - do not opacity mpa, but use geometry rgds, nisus Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 29, 2006 Author Share Posted June 29, 2006 I had thought of the Facade map, but havn't tried it yet, whats not working for you? In the examples all the reflections are calculated with a Raytrace material, I'll check the refraction settings, Off the top of my head I think no refraction is being calculated. Thanks for the suggestions, but I think that this is a bug that needs to be reported. JHV Link to comment Share on other sites More sharing options...
