charadesia Posted June 3, 2006 Share Posted June 3, 2006 hi, im a newbie in everything regarding 3d modeling, im just doing a little animation using max 7 with vray... the problem is the animation is flickering... it seems like in every frame rendered, a slightly different shade of color is rendered, that's why when it is animated, we get the flickering effect... im doing a flyby animation of a building... btw, some follow up questions: 1. what codecs should i be using? 2. what size/resolution should i use? 3. what screen aspect ratio? 4. how to get rid of the flickering of the animation the animation will most likely be played on a tv and also will be projected into a wall, it is part of a gimmick during the launching/inauguration of the said building... hoping to hear from you guys and thanks in advance... Link to comment Share on other sites More sharing options...
colorID Posted June 3, 2006 Share Posted June 3, 2006 hi, if the animation will be played on the T.V i guess u have to choose between Pal or NTSC,the one that suits the broadcast in ur country,u can get that from the output size. regarding the flickering please post ur vray settings and lets see whats wrong with it. regards. M.J.Anani Link to comment Share on other sites More sharing options...
RamiroB2 Posted June 3, 2006 Share Posted June 3, 2006 http://www.cgarchitect.com/vb/16830-please-help-me-about-animation-moving-objects.html?highlight=flickering http://www.cgarchitect.com/vb/16964-rendering-flicker-animation.html?highlight=flickering Link to comment Share on other sites More sharing options...
