proces2 Posted June 6, 2006 Share Posted June 6, 2006 I have a polygon mesh from Rhino that i need to simplify. Is there a software out there or a plug-in for something like Rhino or MAX that can take a large polygon mesh and cleanly simplify the model - ie - reduce the poly count? This is for a model that is being built on an SLA machine. Because of the current high poly count, the machine will not accept the file. i looked at something like PolyTrans, but it was hard to determine if that was a function inside the software. any suggestions would be great. thanks, sean Link to comment Share on other sites More sharing options...
Brian Smith Posted June 6, 2006 Share Posted June 6, 2006 Optimize doesn't doesn't do it well enough? Link to comment Share on other sites More sharing options...
derijones Posted June 6, 2006 Share Posted June 6, 2006 Have a look at Deep exploration - their CAD tools have a good poly reduction tool, not sure about price, but it's a handy bit of kit for viewing heaps of different files. Link to comment Share on other sites More sharing options...
joseph alexander Posted June 6, 2006 Share Posted June 6, 2006 downloard rhino 4. "QuadrangulateMesh" this may reduce your mesh count 1/3 Are you meshing a nurb? To do so do the following: reduce it to the size of the part 1:1 scale. make sure your units are in inches. then mesh using these settings. maximum angle: 0 maximum aspect ratio 6 minimum edge length .0001 maximum edge length 0 maximum distance, edge to surface .001 Check: Refine Mesh all else unchecked export. Link to comment Share on other sites More sharing options...
