alfienoakes Posted June 12, 2006 Share Posted June 12, 2006 Did you change the quality setting in your IR map..? If so check what the "Blur GI" value is set to.. If it is not "0" this can cause light leaks.. Link to comment Share on other sites More sharing options...
drew101 Posted June 12, 2006 Author Share Posted June 12, 2006 Hi Andy, Yes I did change my IR settings and I upped my QMC bounces by 1 so I will check the Blur GI tonight and see what effect that has. Cheers Link to comment Share on other sites More sharing options...
mhinks Posted June 12, 2006 Share Posted June 12, 2006 A good improvment. Its looking really nice, the pillars on the left are looking a lot more grounded. The water is cool. Link to comment Share on other sites More sharing options...
FlytE Posted June 12, 2006 Share Posted June 12, 2006 looking much better drew. Personally I think the light did help and the water keeps looking better and better. I would now be inclined to work a little on the wood texture(s) Link to comment Share on other sites More sharing options...
martincg Posted June 12, 2006 Share Posted June 12, 2006 i agree, looking much much better than first one /water is perfect/ - try to use soft shadows in final - beam looks little strange shadowed - try to use smooth modifier on it Link to comment Share on other sites More sharing options...
mahorela Posted June 13, 2006 Share Posted June 13, 2006 mate, this is looking so good now. Your water is perfect and the warmth of the image is great. Much better with the tiles around the edge a different colour but you need to get some heavier bump mapping on them so as the grout is clearly defined, I feel this is a good opportunity to add great texture work to this image. As for the light spot in the corner, usually in my experience this is caused by a modelling error. Check your meshes in that corner, they might not be joined properly. Link to comment Share on other sites More sharing options...
alfienoakes Posted June 13, 2006 Share Posted June 13, 2006 You are right about the modelling error Bob, that will show up as light leaks most of the time, but that will generally show up no matter what settings you use.. the error will always be there. Unless of course you use a really "fuzzy" setting. I had the problem with light leaks on a really tight model, and it turned out to be the "blur GI". When you use higher settings in Vray for your IR Map, ie, high animation, it changes the setting from "0" to "8".. Always worth a look on interiors. Link to comment Share on other sites More sharing options...
drew101 Posted June 13, 2006 Author Share Posted June 13, 2006 Hi Bob, I will check the model tonight Morning Andy, Where do I find the “blur GI” settings? Link to comment Share on other sites More sharing options...
alfienoakes Posted June 13, 2006 Share Posted June 13, 2006 Drew, Go to Renderer tab, then the "Irradiance Map" rollout. Where it says "Built-in Presets" you can change them to suit your scene. Check to see what you have chosen, then look under "basic parameters" the next settings down. It will have your min / max rates, subdivs etc.. then there will be Blur GI. You won't be able to change them though, as they are presets. What you need to do, is under "Current preset" change this to custom. It will keep all of your settings the same, but then you can change them manually. If blur GI is anything other than "0", then try changing it to "0" Link to comment Share on other sites More sharing options...
drew101 Posted July 12, 2006 Author Share Posted July 12, 2006 Hi all I managed to find some time last night and some energy my new job and the Mount Everest of learning curves has taken it out of me a bit anyway I did a little tweaking what do you think? C&C is always needed and welcomed Link to comment Share on other sites More sharing options...
tarek.saade Posted September 18, 2007 Share Posted September 18, 2007 Hello, I Like Really Your Water Material, I Tried,... But My Water Material Is Not Trasparent Like Yuor I Dont Know Why !am Working Over One Outdoor Pool, Could You Tell Me How You Did The Water Material Or If You Could Send Water Mat. Thank You My Email Is tarek.saade@gmail.com Link to comment Share on other sites More sharing options...
deevee84 Posted October 2, 2007 Share Posted October 2, 2007 its good to see where you started and where your ending up. this is a real WIP. thanks for this! shows you what you can do to improve images good work. more of an observer than a critique-r Link to comment Share on other sites More sharing options...
gods418 Posted October 17, 2007 Share Posted October 17, 2007 drew im getting a feeling your more than a perfectionist, you wont stop until its perfect.. i guess yuo can stop now and do other thing Link to comment Share on other sites More sharing options...
kiittea Posted October 17, 2007 Share Posted October 17, 2007 Nice Wip.... its good to see where it ended.. err or is it stil continuing .. nyways nice work drew.. the scene looks a lot better than the first post. But with the interiors so bright I guess the bg shud be much brighter than what it is now - my 2 cents Link to comment Share on other sites More sharing options...
