Duchess VonCrutches Posted June 6, 2006 Share Posted June 6, 2006 Hello, I'm having some issues with anti-aliasing. The renders I get are seriously ugly and dirty. Can I get some advice on how to fix this? Here's what I've been getting. ((Except photobucket is shrinking my image, so you can't see the pixellation... but it's there!)) Link to comment Share on other sites More sharing options...
tcorbett Posted June 7, 2006 Share Posted June 7, 2006 What size are you exporting your images as? I've noticed on occasion that SU doesn't do the best job at antialiasing a line, but I usually crank up my resolution (assuming you have SU Pro) and then shrink it back to where it needs to be with Photoshop. This usually clears things up. Link to comment Share on other sites More sharing options...
Duchess VonCrutches Posted June 7, 2006 Author Share Posted June 7, 2006 Actually, I'm using measurements for tabloid size. When I bring it to 100% in Photoshops, the lines are all pixellated and junk. I'm wondering if it will print that way, or if it will print clear? Either way, I'd like it to look smooth when I go to 100%, so I'm wondering if that's even possible. Link to comment Share on other sites More sharing options...
tcorbett Posted June 12, 2006 Share Posted June 12, 2006 Maybe try going even higher with your resolutions (double?) and then reducing the image size in photoshop. That should smooth out any rough edges. Link to comment Share on other sites More sharing options...
