Amen Posted June 7, 2006 Share Posted June 7, 2006 Hi, I have a problem with max. Whenever I input anything in the window, max is rounding it down anything behind the comma. I dont know why this is happenig and how I can fix it. And I am not ready to reinstall max, yet. Please help me, Thx in advance, Jan Link to comment Share on other sites More sharing options...
a_w Posted June 7, 2006 Share Posted June 7, 2006 Try replacing the comma with a decimal point. Link to comment Share on other sites More sharing options...
kippu Posted June 8, 2006 Share Posted June 8, 2006 customize : preferences : General tab : Spinners : precision .... put in the number of decimal points you want Link to comment Share on other sites More sharing options...
Amen Posted June 8, 2006 Author Share Posted June 8, 2006 I tried the things you said, it did not help, so I just reinstalled max. Maybe there was a plugin problem. I do not know. Thx for your help anyway. Jan Link to comment Share on other sites More sharing options...
tanni Posted June 8, 2006 Share Posted June 8, 2006 Some times I have that type of problem with a little different when I put any numerical figure- enter, it increase the value itself. My solution was making a new file then merge all the object from previous project. You can try. Link to comment Share on other sites More sharing options...
frazer Posted June 8, 2006 Share Posted June 8, 2006 Try making it a whole number then the one you want. Noticed that in the vray render dialog if you want 0.45454545 (the gamma correction thing) then in it will round it up to 0.455 in the render dialog and then after if you type 0.454 it will still round it up to 0.455. However if you put a different whole number in and then 0.454 it will use that value then. Might help if it happens again in the future. Link to comment Share on other sites More sharing options...
