[offer] Batchscripts to switch between two versions
olbo
Hello guys 'n gals!
It came to my attention that a lot of people would like to use
different versions (beta/retail) and would like to switch between
them easily. So I wrote a lil shellscript to do this ...
nb: This is working with the NTFS filesystem only, so if you use
FAT/FAT32 i'm sorry and you are oldschool. =)
1. First off, download junction and copy it to your windows dir
so you can access this tool everywhere. This tool will let you use
symbolic links (NTFS only) like linux ... etc.
2. Install two different Maxwell versions. After that is done, rename
the directories to a different name! You don't have to change the
MAXWELL_ROOT variable, I'll grab it from the environments ...
3. create a textfile with the extension .bat and copy the content
that I'll post below into it.
4. Change all vars on top to the right directorys.
5. Almost forgotten an important thing, the 3dsmax plugins
have to go into different dirs too and the dir that is used for the
"Maxwell_junction_plugin_dir" variable has to be in the 3dsmax
plugin.ini file!
After thinking about workflows, there are two versions
of the batchfile that you can choose from. The first one
will ask you what kinda version you wanna run, the second
will switch between the versions and will not ask. So the
second one is for people that do know what they are
doing. :p:D :D ;)
This batchfile will let you choose between two versions
@echo off
rem ################### Variables to change ##################
SET Maxwell_beta_dir="x:\Maxwell_beta"
SET Maxwell_retail_dir="x:\Maxwell_retail"
SET Maxwell_junction_plugin_dir="x:\3dsMax\plugins\Maxwell"
SET Maxwell_beta_plugin_dir="x:\3dsMax\plugins\Maxwell_beta"
SET Maxwell_retail_plugin_dir="x:\3dsMax\plugins\Maxwell_retail"
rem ###########################################################
:start
CLS
SET Maxwell_version=
SET /P Maxwell_version=Choose between (r)etail or (b)eta:
IF '%Maxwell_version%'=='' goto grmpf
IF '%Maxwell_version%'=='b' goto beta
IF '%Maxwell_version%'=='r' goto retail
:grmpf
ECHO You should type 'r' or 'b' ...
pause
GOTO start
:beta
junction -q -s %MAXWELL_ROOT% %Maxwell_beta_dir%
junction -q -s %Maxwell_junction_plugin_dir% %Maxwell_beta_plugin_dir%
GOTO end
:retail
junction -q -s %MAXWELL_ROOT% %Maxwell_retail_dir%
junction -q -s %Maxwell_junction_plugin_dir% %Maxwell_retail_plugin_dir%
GOTO end
:end
This batchfile will just switch between the two versions without asking anything
@echo off
SET Maxwell_identifier=%MAXWELL_ROOT%\mxed.exe
CLS
IF exist %Maxwell_identifier% (
GOTO beta
) ELSE (
GOTO retail
:beta
GOTO end
:retail
GOTO end
:end
If I missed something ... sorry. ;o)
edit: added point five
take care
Oleg
I forgot to say, that if your pathnames include spaces you
have to use quotation marks!
example:
SET Maxwell_beta_dir="x:\Maxwell beta"
SET Maxwell_retail_dir="x:\Maxwell retail"
SET Maxwell_beta_plugin_dir="x:\3dsMax\plugins\Maxwell beta"
SET Maxwell_retail_plugin_dir="x:\3dsMax\plugins\Maxwell retail"
nb: I will change the first post to save some time. ;o)
take care
Oleg
