Sawyer Posted June 13, 2006 Share Posted June 13, 2006 I am working on a building and I need a section cut through so you can see int and ext. I have come up with 2 options 1. To use Slice mod. This works well but I have 2 issues. a. Objects have no volume they are only faces so I need to add a cap hole mod which has different problems like capping holes in the wrong spot b. This lights the interior with exterior lighting. The work around I have is to use vray dome light. The dome light is not giving great shadows however. 2. Using camera clipping plane. This is cool and gives me a much better affect (It renders the walls a black because they receive no light and it isolates the interior from the exterior so I don't have to light everything with the dome light) but I dont have the control I need to adjust the angle of the clipping plane. It is parallel to the camera and thats that. Also I need to re-render the forground elements that I need. Is there any other option? I like the view plane because it doesn't really open up the building (and it keeps the interior lighting inside exterior lighting out) but I want more control of the cutting angle. Thanks Link to comment Share on other sites More sharing options...
frank1331 Posted June 13, 2006 Share Posted June 13, 2006 There used to be a plug-in you could but called ScalpelMax that worked really well, even with high poly counts. Not sure if its still available or if there is a better way Link to comment Share on other sites More sharing options...
cdos00 Posted June 13, 2006 Share Posted June 13, 2006 Sawyer ScalpelMAX is developed by CEBAS software, I have included a link below. I haven't personally used the software but it looks AWESOME! http://www.cebas.com/products/products.php?UD=10-7888-33-788&PID=6 Link to comment Share on other sites More sharing options...
Sawyer Posted June 13, 2006 Author Share Posted June 13, 2006 I remember that. Anyone know if you can light the scene pre-cut then render the cut without the lighting taking into accountthe opening? I e-mailed Cebas. Link to comment Share on other sites More sharing options...
