e-YELLOWCABS.COM Posted June 14, 2006 Share Posted June 14, 2006 hi everyone ! i saw in chaos site we can use D-Rendering only with a vray 1.46?!?! is it for that 1 can not use it with the "700 boxes" v1.4703 ? can i use the dr from max with vray over the top? thanks for help ! pierre:confused: Link to comment Share on other sites More sharing options...
gfa2 Posted June 14, 2006 Share Posted June 14, 2006 I use DR with 1.47.03 everyday. I'm pretty sure you can only use 10 computers per licence though. I've never tried more than 10 becasue I'm pretty sure I read that in the documentation. Link to comment Share on other sites More sharing options...
e-YELLOWCABS.COM Posted June 15, 2006 Author Share Posted June 15, 2006 hi ! lucky you are !!! have you got static ip address or dynamic ones ( via hubs) ? i can see my servers with an ip address, but during the render, vray logs that DR rendering failed!!! have you got an idea ? thanks Link to comment Share on other sites More sharing options...
gfa2 Posted June 15, 2006 Share Posted June 15, 2006 I have static ip. check this link out, it pretty much has everything you need to know. http://www.spot3d.com/vray/help/VRayHelp150beta/distributed_rendering.htm It sounds like you might not have the vrayspawner running on each of the render nodes. Link to comment Share on other sites More sharing options...
