Zooming problen in modeler
claudioarchi
Hello there, i'm modeling a curtain wall with a spider anchor. My model is an real scale, so the wall is pretty big. When i zoom to it in any orthographic view (top, right, front, etc.) i have a limit, i can't get closer to the spider anchor to work the details. But in the perspective view seems to work. the grid unit is set to 1 2. 5 5 and i'm working in millimeters. I've been having this zoom problem for a while now but it's getting really disturbing. If you guys have any idea...Please... the file is attached in this thread.!!!!!
thank you all
see ya
Claudio,
I had this problem before.
I don't know why but if you centre the entire object closer to the 0,0,0 axis point, you'll be able to zoom right in.
Let me know if you get it working.
IC,
You'r so right man!!!! it works....hmmmm!!!! very strange problem?. I centered the object and it zooms perfectly...it's sad my model is to advanced now to center it all...Too late, any ways thanks for the tip it works perfectly!!!!!...
See ya!!!!
Claudio,
I did this and was able to zoom in very close. Must be something about having the model so far away from center. Good suggestion!
to make any point in your model space environment the current pivotal point for zoom... select a point or poly at that point you want to edit and press ( Shift+A )... you now are zoomed in and can rotate your views around that area and edit away.
that is, if I am understanding the issue you are talking about properly
