chodney Posted June 14, 2006 Share Posted June 14, 2006 We're working on about 85 interior renderings for a local condo building. These will all be fully detailed, with furniture, and other entourage. As you can see, we're still working on modelling all the appliances, etc. but feel that the materials are done. I'd appreciate any critique or helpful comments you have on the lighting, materials, composition, or even post-processing ideas. thanks Link to comment Share on other sites More sharing options...
manta Posted June 15, 2006 Share Posted June 15, 2006 Looks good so far, materials and lighting ! Link to comment Share on other sites More sharing options...
kulbir bal Posted June 15, 2006 Share Posted June 15, 2006 coming up really good Link to comment Share on other sites More sharing options...
sardesign Posted June 15, 2006 Share Posted June 15, 2006 floor boards look a bit big (but i guess there are wood floor planks that come that wide). looks good, a bit too bright at the left part of the image (is there alot of glazing there?) Link to comment Share on other sites More sharing options...
chodney Posted June 15, 2006 Author Share Posted June 15, 2006 thanks for the comments so far. the floor boards are correct....6" wide and you can scale them off the wall base (also 6"). we've had a real problem with the glass. I used a Vray material originally but had a problem making it reflect without having to turn the fog color and thickness way up, which of course made it look too dark. this material is just a standard material with a Vray map for the reflection. It's causing some serious color burn at the top of the windows, or wherever there is dark color on the background. any recommendations? images would help thanks Link to comment Share on other sites More sharing options...
