myth Posted June 19, 2006 Share Posted June 19, 2006 How to make realistic looking rugs like the one in the image Link to comment Share on other sites More sharing options...
Mario Pende Posted June 19, 2006 Share Posted June 19, 2006 I think youll have to model for this one a volume and then add very sharp displacement. Link to comment Share on other sites More sharing options...
anvaraziz Posted June 20, 2006 Share Posted June 20, 2006 vray displacement ll do the trick... also u can try vray fur.. but takes hell lot time to render,,,, Link to comment Share on other sites More sharing options...
UTI Posted June 20, 2006 Share Posted June 20, 2006 anvaraziz said: vray displacement ll do the trick... also u can try vray fur.. but takes hell lot time to render,,,, can anyone explain how it is done bye vray displacement??? Link to comment Share on other sites More sharing options...
ipdesigner Posted June 20, 2006 Share Posted June 20, 2006 UTI said: can anyone explain how it is done bye vray displacement??? *if you are using Vray render engine, you can apply to an object quietly doing better on plane the 'Vray Displacement' modifier:) . it gives a good result for carpet and even on grass. Link to comment Share on other sites More sharing options...
anvaraziz Posted June 21, 2006 Share Posted June 21, 2006 UTI said: can anyone explain how it is done bye vray displacement??? hope this ll help u... Link to comment Share on other sites More sharing options...
BunGHoLe Posted June 21, 2006 Share Posted June 21, 2006 anvaraziz could you tell us why you apply MeshSmooth but you keep the Iretations to 0? Is it better that way and why? Link to comment Share on other sites More sharing options...
GeraldH Posted June 21, 2006 Share Posted June 21, 2006 ...that's some thick-ass ruggage... Link to comment Share on other sites More sharing options...
UTI Posted June 22, 2006 Share Posted June 22, 2006 thanx alot anvar .................... and ipdesigner 2 Link to comment Share on other sites More sharing options...
FlytE Posted June 22, 2006 Share Posted June 22, 2006 I dont think the meshsmooth(iterations=0) is proabably necessary if you are using a vray displacement mod. You would really only use that if you were using displacement in the material itself. Usually people apply the meshsmooth on order to make the displacement map wrap around the geometry and join at all sides. In normal displacement, the texture will often appear offset from the geometry meaning that it wont join at the edges. The meshsmooth with iterations=0 just pulls it back into the face so the displacement meets at the edge again. Link to comment Share on other sites More sharing options...
Thablanch Posted June 22, 2006 Share Posted June 22, 2006 You do need to smooth it, even if it is the modifier, or else, your edges are opening Link to comment Share on other sites More sharing options...
FlytE Posted June 22, 2006 Share Posted June 22, 2006 Im too tired to try it for myself, so I will just take your word for it Link to comment Share on other sites More sharing options...
FlytE Posted June 23, 2006 Share Posted June 23, 2006 the geometry probably needs a rug texture. the vray displacement mod's black and white texture is only for creating the bump that you see, the actual rug material texture is applied as normal to the geometry. Link to comment Share on other sites More sharing options...
anvaraziz Posted June 27, 2006 Share Posted June 27, 2006 u can texture it with ur own maps, normaly i use fall off maps on diffuse with 2 colors, LINK for the displace map Used in this tuto.. Thanks..... Link to comment Share on other sites More sharing options...
fabricf Posted July 20, 2006 Share Posted July 20, 2006 when I put the vray displacement map in the plane the tiles of my image doesnt ajust with the tiles on the material.... how can i change it??? Image 1 without the displacement ( is this the correct tile setup) image 2 with the displacement.... (but it doesnt repeat the image in 5 ways that is the correct scale) =( Link to comment Share on other sites More sharing options...
evanmister Posted July 20, 2006 Share Posted July 20, 2006 when i try this tutorial i get an error from vray that says: "invalid surface normal (0,0,0) for box01, using geometric normal" why is that? thanks Link to comment Share on other sites More sharing options...
