NOOXY Posted June 19, 2006 Share Posted June 19, 2006 Hey Guys, i have a tablet input device at the office and tried hooking it up to my system so that i can draw splines more flexible by freehand.my question is 1. does c4d support the use of tablets; 2. can you use it as a substitute to their splines, 3. if it does work how do you guys use it in accordance to modelling your splines. 4. do uall use tablets for modelling, and which software can use it so that it can be imported into c4d thanks all:cool: Link to comment Share on other sites More sharing options...
edub Posted June 20, 2006 Share Posted June 20, 2006 Hey Guys, i have a tablet input device at the office and tried hooking it up to my system so that i can draw splines more flexible by freehand.my question is 1. does c4d support the use of tablets; YES (see attached image for pref setings) 2. can you use it as a substitute to their splines, ?? 3. if it does work how do you guys use it in accordance to modelling your splines. I use the tablet for everything - no mouse! 4. do uall use tablets for modelling, and which software can use it so that it can be imported into c4d see above - but I'm not sure I understand why you can't model in C4D... that's what I do, although the tablet works in all software (that I have, anyways), so it shouldn't be a problem drawing in illustrator and importing, if you'd rather go that way. Link to comment Share on other sites More sharing options...
NOOXY Posted June 20, 2006 Author Share Posted June 20, 2006 thanks for the reply man..really appreciate it. i'll try it out and keep posting. I just wanted to know if it was faster in modelling fancy splines instead of using the mouse in c4d.. Link to comment Share on other sites More sharing options...
