superdave Posted September 7, 2002 Share Posted September 7, 2002 I'm having a hard time opening files that are from 3dViz (the latest version) to 3d max 3.1 are they not compatible. I know I can't Open Max 4 files in Max 3.1, Maybe the problem i'm having is similar I don't know. I'm realy hurting here. Please Help Me Cg Community!!! Link to comment Share on other sites More sharing options...
STRAT Posted September 7, 2002 Share Posted September 7, 2002 i dont know if there is a convertion plug-in available but you can certainly save them as .3DS files whilst retaining nearly all of the same info. Link to comment Share on other sites More sharing options...
plastic Posted September 7, 2002 Share Posted September 7, 2002 try this script: http://www.scriptspot.com/bobo/darkmoon/bff/ or use the 3ds format. Link to comment Share on other sites More sharing options...
vizwhiz Posted September 7, 2002 Share Posted September 7, 2002 hi There, superdave here is a url to a VIZcopytool.exe which ithink can help convert VIZ into Max format, this may or may not work for VIZ (latest) back to Max 3.1: ftp://ftp1.discreet.com/web/support/3dstudio/vizcopytool.exe There is an issue that VIZ4 files will NOT open in VIZ3 (let alone Translate them into MAX) the above link was found at: http://www.viz2000.com/html/3110viz-linkquik.html i hope This helps Thanks Randy www.viz2000.com Link to comment Share on other sites More sharing options...
