Chaning color of 'Frozen' Layer in Max
Michael Emo
Anyone know how to change the default color of a 'Frozen' layer in Max? I always import CAD layers and then Freeze them. But I've always had trouble seeing lines unless I changed my UI Environment to have a black background.
I know how to change the 'Active' color of the layer, but default color for Frozen Layers in Max is grey. And when I work in a UI with a grey background, obvisouly this doesn't work so well :p
Thanks,
Michael
  • 11 months later...
hijacking this thread for a related question.....
I can change the color of frozen objects, and I know how to tell an object to retain it's normal color when frozen.....
but is there a way to globally set it in the scene so that all frozen objects retain their original color?
(i'm giving it my first shot at totally abandoning form-z for modeling and going all max today, and I keep accidentally shifting objects)
Hum.... never thought of that... I guess you could set all objects to have their properties set by layer (Customize -> Preferences) and set your layers to do it. Not sure if you can create like a rule to every new layer, but I'm gonna look a little deeper into this one....
Select all objects, go to object Properties and uncheck "Show frozen in gray"
hmmm... not the full global change that I wanted.... such that as new objects are added you'd have to keep applying the change..... I was hoping there was a setting somewhere that would make the change apply to new objects as well....
but a good suggestion all the same.... thx
