alekzab Posted June 22, 2006 Share Posted June 22, 2006 i have this problem with cameras. I am using max 6 so when i render across the network the backburner cant access the camera scene as an xref. it will output an error saying cannot find camera. so what we are currently doing is merging the camera in the host file and then we render, so no problem with that...fine and dandy. my problem is the users who use the files. if they move my cam by a liitle it throws the animation off sync, since i am rendering in layers sometimes the composite wont line up. is there a way to lock the camera and keep users from moving it? this is max 6. thanks Link to comment Share on other sites More sharing options...
BrianKitts Posted June 22, 2006 Share Posted June 22, 2006 I don't remember if this was available or not in 6.... but to "lock" my cameras, I just right click on them and say "Freeze selected".... then their locked unless someone purposely unfreezes them.... Link to comment Share on other sites More sharing options...
Justin Hunt Posted June 23, 2006 Share Posted June 23, 2006 Blur scripts has something that "locks" objects, Look in scriptspot.com JHV Link to comment Share on other sites More sharing options...
alekzab Posted June 23, 2006 Author Share Posted June 23, 2006 thats true, you can freeze the camera, but if you select the camera and go under that view you are able to move it with your zoom/pan buttons on the lower right. Link to comment Share on other sites More sharing options...
alekzab Posted June 23, 2006 Author Share Posted June 23, 2006 Blur scripts has something that "locks" objects, Look in scriptspot.com JHV cool let me try that! Link to comment Share on other sites More sharing options...
3danim8d Posted June 23, 2006 Share Posted June 23, 2006 Can you disable the viewport displaying the camera-pov so the other users can't dolly/truck/or zoom ? Link to comment Share on other sites More sharing options...
Renato1 Posted June 23, 2006 Share Posted June 23, 2006 The other thing you can do is to lock the Move, rotate and scale of the camera. This is in the command Panel under the "Hierachy" tab in the "link info" tab. Just tick the boxes there and you will not be able to do anything with the camera. Link to comment Share on other sites More sharing options...
IC Posted June 23, 2006 Share Posted June 23, 2006 Pretty software specific topic for 'General Discussions'. Link to comment Share on other sites More sharing options...
