Dual processor - Dual Core + max
hello folks,
I'm just about to buy a new workstation... zzzzzzzzzzzzzzzzzzzz i know. I wont bore anyone with the specifics though.
I was just wondering whether the 3ds max + Vray combination that i use can render with any more than 4 buckets? i.e. can it utilise any more than 4 processors?
At the moment I use a dual 3.2ghz xeon system, with hyperthreading turned ON. So Vray (and task manager etc) sees 4 processors.
If i buy a dual core - dual processor system, and turn the hyprethreading on, will Vray, max etc see 8 processors? If it cant then I struggle to see the benefits of dual core, dual processor systems.
cheers
a true dual core cpu will dramatically out perform a single core hyperthreaded CPU even tho Vray and task manager will both indicate 2 processors available.
hyperthreading isn't actually 2 cores its tricking windows.........dual core CPU are actually 2 CPUs
I realise that hyprethreading isnt actually creating two cpus... however, I've noticed a pretty significant speed boost by turning HT on.
I was really asking whether Vray and max could take maximum advantage of a dual core, dual processor system with the HT turned on... as in... can it use all 4 logical, and 4 virtual processors. Or would you have to leave it with HT off?
yes it can, however the best (reasonable priced) dual core procs are the AMD versions which don't support hyperthreading. i believe that intel do a dual core CPU that has hyperthreading but i know it used to be very expensive in relation to the AMD's and i have no idea if it was actually any faster etc.
I think Vray can support upto 10 buckets per render, these can be obtained via a multiproc setup or thro DR.
why not wait for the Conroe from intel? based from all the tests, the Conroe totally wiped every processor out there. Expect a 30-50% drop in single core chips.
as far as i know the Conroe should be out in 2-3 months or so
If you wait for the next gen, when you get it it won't be the next gen anymore :) It's a losing battle. Buy the hardware when you need it.
agreed! ... and enjoy the price cuts of the stuff already out there because of that "next gen" stuff
conroe is supposed to be out this month... dunno where it is though:confused: :confused: :confused:
