Spayer Brick Heads
Trevor Tizard
i'm afraid not.....you want to use the uvw unwrapp tool.......i like your idea tho would make our jobs much easier for such a common feature. UnwrappUVW seems very overkill for something so little.
suppose you could always taper the texture in p'shop first aswell, may be easier
If you create a regular box, the uvw map it as a box, then apply a taper modifier to the box AFTER you UVW it, the map will taper with the box. The only catch is that sometimes the brick map will get jaggy along the face of the brick, so you have to add additional segments to the box when you create it.
