lala18 Posted June 23, 2006 Share Posted June 23, 2006 Used loft, Helix, Path deform, have not been able succeed. With loft it’s one part goes vertical, other part to wrong side. Trying use loft’s twist. But no use. Pls help. Thx. Link to comment Share on other sites More sharing options...
raterry Posted June 23, 2006 Share Posted June 23, 2006 can you be more specific as to what you are tyring to achieve? IS the image your showing us what is going wrong? If so tell us what you want it to look like or send an example image. -=Rob Link to comment Share on other sites More sharing options...
STRAT Posted June 23, 2006 Share Posted June 23, 2006 i'd personally draw and shape a 3d spline in exactly the possition/direction of where you want the stringer to go, in 3d space, then simply loft a rectangle along it using the compound objects loft option Link to comment Share on other sites More sharing options...
noi-pi Posted June 23, 2006 Share Posted June 23, 2006 Make a Spline (Line) to where the stringer runs.... Now select the spline sub-object of the Line... Activate OUTLINE on the geometry rollout and enter your value (thickness)... Then apply Extrude modifier for the height. Link to comment Share on other sites More sharing options...
lala18 Posted June 23, 2006 Author Share Posted June 23, 2006 i'd personally draw and shape a 3d spline in exactly the possition/direction of where you want the stringer to go, in 3d space, then simply loft a rectangle along it using the compound objects loft option [With loft and with other methods it’s one part goes vertical, other part to wrong side. One part fine, other part turning 90degree. See? And with all methods the same thing. Thx What is the result. Link to comment Share on other sites More sharing options...
lala18 Posted June 23, 2006 Author Share Posted June 23, 2006 I attached 3d file of this stair too. Link to comment Share on other sites More sharing options...
raterry Posted June 23, 2006 Share Posted June 23, 2006 can you be more specific as to what you are tyring to achieve? IS the image your showing us what is going wrong? If so tell us what you want it to look like or send an example image. -=Rob To quote Napolean Dynamite "What an idiot" I should've paid more attention to the the actual subjuct of this threat before wasting space. Sorry. Maybe its a matter of the loft "banking" along the curve.? Link to comment Share on other sites More sharing options...
lala18 Posted June 23, 2006 Author Share Posted June 23, 2006 To quote Napolean Dynamite "What an idiot" I should've paid more attention to the the actual subjuct of this threat before wasting space. Sorry. Maybe its a matter of the loft "banking" along the curve.? banking is on Link to comment Share on other sites More sharing options...
lala18 Posted June 23, 2006 Author Share Posted June 23, 2006 Make a Spline (Line) to where the stringer runs.... Now select the spline sub-object of the Line... Activate OUTLINE on the geometry rollout and enter your value (thickness)... Then apply Extrude modifier for the height. Hi. Thx. But while I’m using ur advise it extrude height, but should do with width.? Link to comment Share on other sites More sharing options...
noi-pi Posted June 23, 2006 Share Posted June 23, 2006 The value for the Outline will serves as your width....that is before you applied extrude modifier. Its the simplest solution I could think of. Link to comment Share on other sites More sharing options...
noi-pi Posted June 23, 2006 Share Posted June 23, 2006 Fortunately, I'm not busy today... Heres the screen grab and the Max file. Link to comment Share on other sites More sharing options...
lala18 Posted June 23, 2006 Author Share Posted June 23, 2006 Fortunately, I'm not busy today... Heres the screen grab and the Max file. Thank u. But I’m using 3DS MAX7, so I’ve not been able to open. Link to comment Share on other sites More sharing options...
noi-pi Posted June 24, 2006 Share Posted June 24, 2006 Thank u. But I’m using 3DS MAX7, so I’ve not been able to open. Have no fear. Here's Version 7.1.... Link to comment Share on other sites More sharing options...
lala18 Posted June 27, 2006 Author Share Posted June 27, 2006 Have no fear. Here's Version 7.1.... Thank u very much. Ur advise looked me strange, because I’d been using the “outline” wrong:confused: . Clever solution.Thx again:cool: . Link to comment Share on other sites More sharing options...
