anindia Posted June 23, 2006 Share Posted June 23, 2006 can anybody guide me, how can array an object 10 times not in linear but in polar pattern. actually when i am using autocad its very easy to assign polar array, but in 3d max array i could not do it. i ve tried multiple times but everytime it happens like linear array. help me pls. Link to comment Share on other sites More sharing options...
raterry Posted June 23, 2006 Share Posted June 23, 2006 Try using the snapshot tool. It's very effective for a variety of arrays. There's pretty good info in 'help' but if you need more let me know, I'll help you through it. -=Rob Link to comment Share on other sites More sharing options...
noi-pi Posted June 23, 2006 Share Posted June 23, 2006 Select the object you want to array.... Then on the Heirarchy tab activate Affect Pivot Only... Move the object's pivot to where you want as its center... On the Array Dialog box just put some degrees value on the Rotate. ...but make sure your in Orthogonal views. Link to comment Share on other sites More sharing options...
