harrowboy Posted June 24, 2006 Share Posted June 24, 2006 sorry for the vray version problem. removing the post here:) thx for the tips alex and steve. Link to comment Share on other sites More sharing options...
cgbies Posted June 24, 2006 Share Posted June 24, 2006 noted your default light in global switch is check = Default light have to be off (uncheck).Next check all light in vray shadow mode.Hope that helps. Link to comment Share on other sites More sharing options...
redlancer Posted June 24, 2006 Share Posted June 24, 2006 I think the 'default lighting' check box is overridden once you put a light in the scene, so it wouldn't matter if it's on or off. You might experimenting with light cache for your secondary bounce. Lately I've been using IR+LC for interiors and IR+QMC for exteriors and getting pretty good results. It always feels (to me, anyway) like the QMC on interiors can't 'push' enough light into the scene. You can try bumping up the bounces on the QMC, but I've found anything above 6-8 doesn't change things too much. SteveJ Link to comment Share on other sites More sharing options...
antonio_frias Posted June 24, 2006 Share Posted June 24, 2006 V-Ray 1.49.03 ????????? Link to comment Share on other sites More sharing options...
jow Posted June 24, 2006 Share Posted June 24, 2006 Yeah dont think you should be posting here with Vray 1.49.03, Read the thread at the top of the page.... Link to comment Share on other sites More sharing options...
