yogeshwagh Posted June 27, 2006 Share Posted June 27, 2006 hi to all, I post you the image with two diffrent wood textures and in sizes also. but when it renders it gives me some grainy specular and diffuse too. so please help me about it. how can i get the smooth feel to my material . My Material Settings are as follows : High glossiness :0.75 Refl. glossiness : 0.75 Reflection value :20 RGB falloff map with the fersenal reflection to the reflection map. Primary engine : Irradiance Map settings : high animation settings with four passes and others are on default. secondary Engine : Lightcache Subdivs : 800 samples : 5 Pre filter : 20 And all other are by default. Environment Reflection checbox is on multiplier is 1 Environment GI Multimplier is 1 Link to comment Share on other sites More sharing options...
kippu Posted June 27, 2006 Share Posted June 27, 2006 i suggest you go through the settings and what they stand for in the vray manual ... will help you in the long run Link to comment Share on other sites More sharing options...
Clifton Santiago Posted June 27, 2006 Share Posted June 27, 2006 The problem you are pointing out is caused by your reflection glossiness subdivs being too low. Try upping it to 24. Check the "Use interpolation" for speed (like an IR map for glossiness). Otherwise it will use brute force. Do not check it for animations. Link to comment Share on other sites More sharing options...
