thickly Posted June 27, 2006 Share Posted June 27, 2006 My machine at work just got switched out, now the middle scroll wheel is scrolling instead of zooming. I went through all the menus and couldn't find where I can change this setting. Please help! SD Link to comment Share on other sites More sharing options...
Camby1298 Posted June 27, 2006 Share Posted June 27, 2006 Through your computer's control panel, there is a mouse icon, open it up. On one of the tabs on the top there will be a wheel call out, where there will be a wheel trouble shooter toward the bottom (if you have windows XP). Have ACAD running while going through your trouble shooter and you should be able to fix your problem. Link to comment Share on other sites More sharing options...
angelo Posted June 27, 2006 Share Posted June 27, 2006 Try MBUTTONPAN in acad. If this is already on, then try turning on "Compatible with Office 97" in your mouse control panel. Good luck, Angelo Link to comment Share on other sites More sharing options...
neil poppleton Posted June 28, 2006 Share Posted June 28, 2006 mbuttonpan, will do the trick in the command line within autocad Link to comment Share on other sites More sharing options...
thickly Posted June 30, 2006 Author Share Posted June 30, 2006 just wanted to say thanks for the replies -- the "Compatible with Office '97" did the trick -- now one of my co-workers has the same issue and that option is not available under his Control Panel/Mouse/Wheel menu. With mbuttonpan, what value do you enter after the command? I think you can only enter "0" or "1" -- but I can't seem to get anything to work on his machine. I gotta tell you, I don't know how anyone works without the zoom wheel! thanks SD Link to comment Share on other sites More sharing options...
