fts Posted June 28, 2006 Share Posted June 28, 2006 Why is Vray Rendering crashing when I have TreeStorm objects? See error message attached, Anyway to fix that? Thanks Link to comment Share on other sites More sharing options...
Brian Smith Posted June 28, 2006 Share Posted June 28, 2006 Here are the typical reasons. http://www.spot3d.com/vray/help/VRayHelp150beta/troubleshooting.htm You can check the c:\vraylog.txt file for more clues or call Onyx and see if they can help. I've never had any problems with it. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 28, 2006 Share Posted June 28, 2006 TreeStorm objects are quite high-poly. My guess is your machine can't handle many objects like that. As a workaround, try converting the trees into VRayMesh (Proxy). Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted June 29, 2006 Share Posted June 29, 2006 TreeStorm objects are quite high-poly. My guess is your machine can't handle many objects like that. As a workaround, try converting the trees into VRayMesh (Proxy). i second that. Link to comment Share on other sites More sharing options...
fts Posted June 30, 2006 Author Share Posted June 30, 2006 I tried converting the trees into VRayMesh (Proxy). but when i reemport them in max i get red objects with no materials. please advice. Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted June 30, 2006 Share Posted June 30, 2006 Create a multi-sub object material for the trees before converting them. Then, after you import the Proxy, apply that same material to it. That should do. Link to comment Share on other sites More sharing options...
fts Posted July 5, 2006 Author Share Posted July 5, 2006 Hey thanks a lot. Can I clone the Vray meshes once in my scene or each one has to be imported via the VrayProxy mesh import in the create in the command panel? Thks Link to comment Share on other sites More sharing options...
arquiteck09 Posted July 5, 2006 Share Posted July 5, 2006 you can clone it as instances, that way all the proxys have the same material Link to comment Share on other sites More sharing options...
