marcbon31 Posted July 6, 2006 Share Posted July 6, 2006 this is a smmal render for testing but even with a bigeer size a have the same problem but not so evident,, shaggi edges...which parameters affect this the most.... iradiance map mediun-50-20 ligt cache sub 1000 qmc0.85 0.002 mins1-global sub4.0 antialiasing..adaptive qmc 1-4....filter catmull-rom thanks Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 6, 2006 Share Posted July 6, 2006 Well, Marcelo, it's kindda hard to see anything... could you post a bigger version? Link to comment Share on other sites More sharing options...
FlytE Posted July 6, 2006 Share Posted July 6, 2006 I suspect it is your catmull rom antialiasing. Try another setting or maybe just put it back to area? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 6, 2006 Share Posted July 6, 2006 if you are using 'adaptive QMC', you need to up your QMC sampler. there are several settings, but i use.. adaptive 0.85 noise 0.001 min samples 12 global 5.0 or try using 'adaptive subdivision'. Link to comment Share on other sites More sharing options...
marcbon31 Posted July 6, 2006 Author Share Posted July 6, 2006 I will try... Link to comment Share on other sites More sharing options...
