justintime1 Posted July 6, 2006 Share Posted July 6, 2006 Hi there, your help would be hugely appreciated! As you will appreciate from the Sean i'm constructing i'm a complete novice with 3dmax. My problem iv encounted is that within the perspective view the objects aren’t being drawn correctly and when they are rendered bits are missing??? Rather odd, as in the plan and section views the mesh seam to be intact... and i can see no reason why they wouldn’t be. see atached image, Any help would be greatly appreciated, I only set about teaching my self Max this evening and already iv hit a bit of a hold up. many thanks Matt Link to comment Share on other sites More sharing options...
diegofer_9 Posted July 6, 2006 Share Posted July 6, 2006 How did you model this object? I think is the direction of the normals. If you apply a standard material with 2-sided checked and it renders fine, than your normals are pointing in the wrong direction and you have to flip them. That's what I think. Good luck, Link to comment Share on other sites More sharing options...
manta Posted July 6, 2006 Share Posted July 6, 2006 Its inside out, you can either force 2 sided in the render globals, assign a 2 sided material or check the flip normals in the lathe modifier... Link to comment Share on other sites More sharing options...
justintime1 Posted July 6, 2006 Author Share Posted July 6, 2006 Thanks a million folks. Little things like that are going to drive me bonkers for a wile im sure, I spent four years using cinema and it a hole lot more simple. Im sure this wont be the last Post I make wile teaching my self this program.. Many thanks . Link to comment Share on other sites More sharing options...
manta Posted July 7, 2006 Share Posted July 7, 2006 Well as long as you keep asking these easy ones...hehe Link to comment Share on other sites More sharing options...
Juan Altieri Posted July 7, 2006 Share Posted July 7, 2006 you will need to filp the faces, i don't know how you draw this, if you are using the lathe modifier, you will need to click the "flip faces" on modifier pannel as manta says... Link to comment Share on other sites More sharing options...
justintime1 Posted July 10, 2006 Author Share Posted July 10, 2006 Thank you every one ,extremely helpful as usual. Many thanks. Link to comment Share on other sites More sharing options...
