Retail clothes problem
DaveP
The trouble is that this is just a small demo, part of a bid, the actual project has over 200 garments and many more accessories, so i have to find the most efficient way of doing the final 20 Vray views and a animation.
thanks for comments so far
DaveP
What I would try:
Firstly, make the hangers and t-shirts a seperate object. Do a mesh select of all the vertices EXCEPT those very close to the neck, and where the hanger would go into the shirt (they should be more rigid). Add a turbo smooth modifier, and change the iterations to 2 or so (maybe just render iters. if you need the computing power while you work on it). Add a noise modifier on top of that, and then change the seed on every shirt, so they appear to be unique t-shirts...
Just an idea. :)
