doujay888 Posted July 8, 2006 Share Posted July 8, 2006 I tried to use one of my friends PC who's having a different setup and still learning to use Vray. Well, my question is...this is my first time to encounter these. I have set the renderer as Vray , however when I tried to open the materials library and each time I make use of Vray mat'l, the mat'l turns out to be black, this happens only with the Vray Mat'l....can any1 help me with this issue? Thanks in advance Guys! Link to comment Share on other sites More sharing options...
aoshinommory Posted July 9, 2006 Share Posted July 9, 2006 mm.... i think that u need to use vray as your material editor renderer....to do this go to render (F10) then under the assign renderer tab there are 3 slots one for the produccion and the second for the material editor, it should be locked or whith vray assigned. Link to comment Share on other sites More sharing options...
