smoothness in curve while importing from Autocadd
viju
hi all,
i am very new to max and have a problem. when i import models with curvature from autocadd to max, they appear fragmented and the texture applied on them behave in a different way altogether......i have tried to increase arc and circle smoothness and segment number in polyline but nothing seems to be working HELP!!!
Viju
For solids with curves in autocad increase the 'Facetres' (that is what the command is called if my memory serves me correctly) to 4 or so, you may want to play with it to get a mesh that has the curvature you want without too much density in your mesh. That command is for solids not 2D polylines, arcs and circles, so if I missed what your question was, I apologize.
when importing to max you should get a pop up dialog box with a variety of import settings. reduce the "Surface deviation for 3D solid"
This is the correct answer. I fought this for quite awhile. Lower this setting from 1.0 to 0.1 and everything will be smooth.
  • 3 months later...
  • 2 weeks later...
when you import Autocad files, in the configure dialogue box check the import check force 2 sided faces or something like that, or use turbosmooth. However, it is more advisable to change all your curves in Autocad into polygons before extruding them. This will also lessen the polygonal faces your computer has to render, because curves in autocad are actually polygons with microscopic faces. Using polygons minimizes the face count. You have to do some experimenting as to how much segmentation is needed without your curves showing the segments.
  • 6 months later...
hi all,
Viju
the simple way is to use (Facetres) and (isolines) Paramaters in autocad
change Facetres from 0.5 as standard to 5-6 and isolines from 4 to 100 and then export to 3Dstudio max as 3ds.and enjoy curves and arcs and ellipses . ?Try that & let me know!
Do you do that before creating your model in autocad, after or it doesn't matter?
i usually used to just go really close by and select the arch and export it to 3ds ...but that was when autocad had the 3ds option :(.... i miss it
Simple , did all your 3D in Architectural Desktop (ADT) and then , export in Auocad ( file/ export/ autocad 2006.2007...) and then to 3ds ( remmmber all coordinates of drawing must be near (0,0,0),
Let me know!
