frank1331 Posted July 10, 2006 Share Posted July 10, 2006 I have created a shape ini AutoCad that I am using for a millwork profile. When I loft the shape as an incidence loft to a rectangle, the profile is on the inside of the box not on the outside. I tried flipping it, but getting the same problem. Any ideas Link to comment Share on other sites More sharing options...
BrianKitts Posted July 10, 2006 Share Posted July 10, 2006 I have created a shape ini AutoCad that I am using for a millwork profile. When I loft the shape as an incidence loft to a rectangle, the profile is on the inside of the box not on the outside. I tried flipping it, but getting the same problem. Any ideas after you have created the loft... select it and under the modify tab, you can open the loft options up (under display leave skin turned off) and click on "shape". You then can click on the instance of the shape that was lofted select rotate and rotate it. (you'll probably have to add a "normal" modifier to flip your normals after you do that... Normally in max if you have that problem you just need to draw the source shapes in a different viewport.... but as for importing the shape... couldn't tell ya... Link to comment Share on other sites More sharing options...
ITryMyBest Posted July 10, 2006 Share Posted July 10, 2006 what i do is go under the loft and select path, then go into spline and reverse it, that usually works Link to comment Share on other sites More sharing options...
Gus_Rayvus Posted July 11, 2006 Share Posted July 11, 2006 hold down ctrl when you select the profile. Link to comment Share on other sites More sharing options...
