mooney102 Posted July 11, 2006 Share Posted July 11, 2006 Hello all, I am creating a sun and shadow study animation in max 8, also using vray and combustion. I want to add a timer on the animation to show the precise time of the day to match the animation of the sun. I would like to add this in post. I am using a daylight system with the correct location. Any Help would be appreciated. Thanks Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 11, 2006 Share Posted July 11, 2006 I remember there was a script that creates a text with the hour, changing it according to the time set in the daylight system. Don't remember the name, but shouldn't be hard to script it, anyway. Link to comment Share on other sites More sharing options...
imgumbydammit Posted July 12, 2006 Share Posted July 12, 2006 scriptspot....search for solar timer.... IGD Link to comment Share on other sites More sharing options...
mooney102 Posted July 12, 2006 Author Share Posted July 12, 2006 Thanks for the replies I'm currently trying to figure out scripting. Any words of advice for my my scripting trials? Link to comment Share on other sites More sharing options...
raterry Posted October 27, 2006 Share Posted October 27, 2006 looking for same thing. Need a time of day stamp for animated shadow study. I found the solar time script on scriptspot and downloaded it but it does not seem to run. Has anyone tried this and have it work or is there another one out there I could try? Thanks. -=Rob Link to comment Share on other sites More sharing options...
wasteland giant Posted September 30, 2010 Share Posted September 30, 2010 http://www.scriptspot.com/3ds-max/scripts/solar-time bump. I'm on max 2010 and this thing don't work. Anyone knows a work around? They REALLy need to patch this somehow into max, because if sketchup can do something similar really easily.. Link to comment Share on other sites More sharing options...
alias_marks Posted September 30, 2010 Share Posted September 30, 2010 (edited) This isn't completely 150% accurate, but I found it close enough for when I was doing something similar... http://vimeo.com/8904804 basically I rendered 5 images and noted their exact time alla the perez weather system files... then keyframed a timer accordingly in after effects. Dropping a timer in after effects is pretty straight forward... if you have trouble I can try to give a more step by step. if you search for timer in after effects there's a widget that dies exactly what your looking for. *edit. my apologies, I see you are using combustion... not sure what the equivilet would be there... Edited September 30, 2010 by alias_marks Link to comment Share on other sites More sharing options...
