Ivy test
signet
Sure
i modelled one ivy leaf (about 8 polygons) and used that as instanced geomtry with particle flow
using position object (on a un-renderable plane ) and speed space follow with some rotation divergence
i actually used 2 planes set back from each other to create some depth there.
mike
thanks, that interesting - seen similar methods using particles and instance geometry in tutorials, never had chance to have a play to date works very well tho.
have you tried it inconjunction with a GI scene yet? would be interesting to see if its feasable in production use?
great technique, it's very convincing ~ thanks for sharing!
@ 286k poly's with only that much coverage (area,volume) will bring a GI calc with a full scene to its knees but I'm sure the lads over @ Uni have a few cows to render on:D
well i think its rendered in vray ...thats a nice thing at 51 secs
no matter rendering engine ~ for that size of an image without anything else in a scene 51 seconds is acceptable but not super
try covering the facade of a building in it an see what happens then... I'm just saying it won't be a quick render. This effect/technique will have to be used wisely (which I'm sure it will)!
signet ~ any plans to animate/grow the ivy? esp since it's already in pflow : )
cheers!
Just to let you all know the render above is GI irr map and light cache.
that was with 5500 instances
the next thing i did:
I have made a wall 24m high and 24m wide. (big wall)
turned the PF source up to 80000 instances and rendered it
from a view where i can see it all in shot
and it rendered in 51 seconds.
not bad at all
( to be honest it crashed a few times trying)
not bad at all
so you increased the primitives by more than 14x and rendered it in the same 51seconds the first image rendered in?
edit: if that's the case I'm buying Vray!
  • 3 weeks later...
not bad at all
... v-ray proxies would lessen system RAM strain (right?) if so that would definitely make the scene more stable. I'm curious to know about the particle instances and stability... ?
