fulin09 Posted July 14, 2006 Share Posted July 14, 2006 Hi this is my first post my name is reagan and i need help with a little problem with my 3dsmax. while im rendering, the window that shows the total rendering time doesn't show up.u know,the window which shows the pause and cancel buttons and the common parameters...so when i have to change something and i want to cancel the render,i can't. i have to wait till it finishes.if i close the window i still have to wait til its over rendering. where can i find this window?i tried reinstalling the software but it's still the same.pls help thank you... Link to comment Share on other sites More sharing options...
Ricardo Eloy Posted July 14, 2006 Share Posted July 14, 2006 First, please, post on the 3ds max section of this forum. You'll get a lot more replies. Second, what resolution are you working on? Low screen resolutions often leave the rendering window out of the screen. A higher resoltuion might fix it (or delete the 3dsmax.ini file). Link to comment Share on other sites More sharing options...
Matt Clementson Posted July 14, 2006 Share Posted July 14, 2006 Pressing ESC will usually cancel a render as well. Link to comment Share on other sites More sharing options...
fulin09 Posted July 15, 2006 Author Share Posted July 15, 2006 thank you very much!esc helps....i tried change the resolution to higher one but still it doesnt show up.well anyway pressing esc would do fine tnx.cgarchitect helps a lot of people kip up the gud work more power to u! Link to comment Share on other sites More sharing options...
fulin09 Posted July 15, 2006 Author Share Posted July 15, 2006 oh im sory,turning the resolution higher does work!thanks! Link to comment Share on other sites More sharing options...
