sofad Posted July 21, 2006 Share Posted July 21, 2006 Hi i have a wood material in my scene and when i render an image this material doesnt work in other words the material render in white without the wood texture. also this error happens when i use vray materials but now my wood material is a standar material multilayer whit a fallof and fresnel reflections. do anybody knows what is happening?? i work whit 3d viz and vray version 1.46 Link to comment Share on other sites More sharing options...
Joseph Petrino Posted July 21, 2006 Share Posted July 21, 2006 looks like you have no UV mapping on those objets. Link to comment Share on other sites More sharing options...
aaron-cds Posted July 21, 2006 Share Posted July 21, 2006 Place a vraymap in the reflection slot for standard materials. In the vraymap place the falloff in the reflection map slot. You would be better off using a vraymaterial for the wood floor for rendering speed. That way you can have glossy reflections as well. Link to comment Share on other sites More sharing options...
Hoa Dinh Posted July 22, 2006 Share Posted July 22, 2006 I think you should post max file, only have floor opject Link to comment Share on other sites More sharing options...
sofad Posted August 4, 2006 Author Share Posted August 4, 2006 thanks but asking a friend told me a tip: when i send to render the scene i have to quit all the previsualization of the materials and the scene becomes only on gray. it's seems like a memory problem but i did this and the problem was solved thanks anyway Link to comment Share on other sites More sharing options...
fm2006 Posted August 4, 2006 Share Posted August 4, 2006 http://www.evermotion.org/vbulletin/showthread.php?t=53287&highlight=viz+2006 look at this hope it helps Link to comment Share on other sites More sharing options...
