jophus14 Posted July 21, 2006 Share Posted July 21, 2006 Here is an image of the scene I have been working on. I need some help on how to liven it up. I didn't put any people or cars in the scene yet because I want to focus on the look of the hotels exterior first. Any ideas or suggestions would be greatly appreciated. I did some post work in PS. Link to comment Share on other sites More sharing options...
NOOXY Posted July 21, 2006 Share Posted July 21, 2006 good start..now some people and cars should liven it up;) ...road texture a bit too dark too Link to comment Share on other sites More sharing options...
Jason Matthews Posted July 21, 2006 Share Posted July 21, 2006 I think if you pick a different sun angle and soften the shadows this may help a bit. Also, correct the color of the trees because they seem too saturated. Link to comment Share on other sites More sharing options...
aaron-cds Posted July 21, 2006 Share Posted July 21, 2006 I like the camera angle. There are a few things troubling me though. The sky looks like a thunderstorm is near. The tree on the left is competing too much with the building. The color of the glass is unrealistic and looks cg. Even if it's tinted glass, I don't think I've seen tinted / reflective coated glass with that color. I may be wrong about the glass though. The trees around the building are all the same. You should try and mix them up a bit. Link to comment Share on other sites More sharing options...
arquiteck09 Posted July 21, 2006 Share Posted July 21, 2006 i like the trees, i don´t think they are saturated, that´s what i think, but maybe some cars and people really should come very good to the scene. Link to comment Share on other sites More sharing options...
Thiago de Andrade Posted July 22, 2006 Share Posted July 22, 2006 you should work on the pavement textures, both asphalt and sidewalks, the trees look weird becaus they are all the same. The environment is also a little "flat", it lacks the surroundings, and a little more depth. Whats that strange panel (or building) behind the hotel? Does it need to be there or can you cover it with vegetation, and let it appear just behind the trees? And I also aggree that the glass texture is odd, perhaps the colour, perhaps the little transparency. The building itself looks good, though. Good luck Link to comment Share on other sites More sharing options...
jophus14 Posted July 22, 2006 Author Share Posted July 22, 2006 Thanks for all of your input. The weird thing behind the hotel are the glass panes of the stairway to the parking garage. Since I am focusing on the hotel I didn't do much as far as detail to the garage. Since the parking garage is on an angle, it looks as though it is just a glass wall. I have to switch some of the trees around so they aren't so repetative. I have been working on the glass to the hotel for 3 days now. The middle panes need to be a white/green transparent material that reflects clouds and the end panes need to be a darker transparent green that reflect clouds as well. I can't seem to get the right green material without it becoming blue due to the sky reflection. It needs to be transparent yet solid enough to reflect the sky. I could use help on getting the glass right. I reflected to clouds off of the glass photoshop, but I hate the way it looks. I'm using a cylinder with a sky mapped on it. I'm looking for a map with nice fluffy clouds a deep blue sky, any suggestions. I found a site that has a ton of sky jpegs, but none with fluffy clouds. Thanks. Link to comment Share on other sites More sharing options...
jophus14 Posted July 24, 2006 Author Share Posted July 24, 2006 Anybody have any input from my last comment? I would appreciate it, thanks. Link to comment Share on other sites More sharing options...
syenilmez Posted July 24, 2006 Share Posted July 24, 2006 If you are going to use trees in a line, it is better to use different images. Because when they come together in the perspective, the image repeats and looks like tiled. Link to comment Share on other sites More sharing options...
Zeilveen Posted July 24, 2006 Share Posted July 24, 2006 Maybe its good to show your latest image if you have changed some settings, overall the image certainly looks very good. Just tweaking it a little more can boost the quality. These are my points: - light falling on building is two flat, create one shaded side and one bright side by rotating the sun - the background is nice but way to blue at ground level, some horizon details would greatly enhance the image - some forground detail would be nice aswell, but maybe the cars / people can deal with that Good luck Ronald Link to comment Share on other sites More sharing options...
jophus14 Posted July 24, 2006 Author Share Posted July 24, 2006 Here's an update of the hotel image. I'm still having trouble with the glass. Any comments will be appreciates. Thanks Link to comment Share on other sites More sharing options...
Zeilveen Posted July 25, 2006 Share Posted July 25, 2006 Thanks for the update, I feel the image is almost done, but needs some little tweaking. I played around with your image in Photoshop to show you what I mean. Its over done, but helps to show the difference: - perspective adjusted, straight line now in corner building, gives it more dramatic feel to it. - bright and dark side added (way to dark, but to show the idea) - different sky with more colour and horizon things - a little filtering to give the image less pale feel Please dont feel offended and hope you see what I mean, Cheers Ronald Link to comment Share on other sites More sharing options...
jophus14 Posted July 25, 2006 Author Share Posted July 25, 2006 I really like the sky (Is it just a jpeg or bitmap?) and the additions to the horizon line. Thanks for taking the time to try out some possible options for the image. Link to comment Share on other sites More sharing options...
Koper Posted July 31, 2006 Share Posted July 31, 2006 If you are going to use trees in a line, it is better to use different images. Because when they come together in the perspective, the image repeats and looks like tiled. yes, sometimes it doesn't look good, but with this image, you kinda don't notice it, it actually works, and remember, we might pick it up, but the average person will certainly have to look very carefully. Link to comment Share on other sites More sharing options...
