3darchitect Posted July 21, 2006 Share Posted July 21, 2006 Dumb question, but I need some help. Ok, so I'm experimenting with drawing walls in 3dsmax using Create, AEC Objects. I've figured out how to adjust the wall's width and height, but I can't adjust it's length. I need to imput precise measurements. Like if I need the wall to be 12" thick, and 10' tall, then how do I specify that it be 11' 9 19/32" long? (or any other measurement for that matter) Link to comment Share on other sites More sharing options...
Quique Posted July 21, 2006 Share Posted July 21, 2006 Hi, If you want to make sure your wall lenth is 11' 9 19/32" long, first make sure your units are set to feet with fraction inches set to at least 1/32", or Max will round up. In order to get a specified length, there's the tedious process of selecting a vertex, snapping it right over the 1st wall vertex, and then manually inputting the distance in X or Y axis. It's extremely cumbersome, I know. Another option is to have these wall lengths drawn in AutoCAD as a simple line, import it into Max and snap to the vertices when drawing your wall. Link to comment Share on other sites More sharing options...
3darchitect Posted July 21, 2006 Author Share Posted July 21, 2006 OOO - Thanks - I'll try the second option, especially because I have an entire floor plan already drawn with lines. How exactly would I go about the importing process? (sorry, I'm a totaly noob to 3dsmax) Link to comment Share on other sites More sharing options...
kippu Posted July 21, 2006 Share Posted July 21, 2006 FILE ---- >IMPORT ---- > browse for the *.dwg file Link to comment Share on other sites More sharing options...
3darchitect Posted July 21, 2006 Author Share Posted July 21, 2006 Ah - I thought as much. Thanks Link to comment Share on other sites More sharing options...
