housin colony
blade911
hi everyone..
jus a housing project im workin on here in the middle east. muscat, oman to be precise..
basically the whole thin was modelled in cad. n as u can see there are some kinda deforms in the kerb area. this was cus i used boolean on cad objects which i know is not recommended. hope someone cud tell me an easy way to fix somethin like this plus on the image as a whole.
i generally wanted to give a conceptual look to the images so didnt do much detailin but i know ive a long way to go...
im relativerly new to max so i wud appreciate all ur c&c..
thanks
Thanks for sharing your work, it looks good to start with. There are some things you may want to change:
- UVW mapping scale of the brick is kinda big
- Trees look very flat, either switch with 3D leaves version or use texture
- maybe use a skydome or layer background the sky looks a bit hard blue to me
- shadows could be a little less dark
Keep posting and you will improof quickly!
Ronald
