Couple of lightwave questions
Hector
Hi:
Question 1: Is there any way of selecting polygons by texture ?. Say: I want to select all objects in layer "x" that have the texture "j" applied
Question 2: (the silly one) I need to use a map to simulate holes on a surface, how do I achieve that?. I am sure this should be very easy but I'cant figure it out.
Question 3: Is there any plug in for instancing?
Thanks
1) Yes, in modeler, press "w" and click and hold down "surface". Select the surface that you'd like to select. And press the "+" button to the left.
2) Not sure exactly what you mean here. Use the image as a tranparency map using your Surface Editor or, in Layout, under "Object Properties, use the image as a clip map. Either works but the clip maps tend to render faster and work MUCH better with instancing.
3) Instancing: I use HD Instance from Happy Digital - great plug in, IMHO.
What a great site! I get it Instacing, I do, do it, but my god my scenes get heavy! specially my cafe I done a few months back. This looks good, BUt can I still render with fprime? I'll go get the demo first. Thanks allen.
Cheers
Cheers
It does NOT work with FPrime as it utilizes volumetrics to create it's instances.
It worked !. How could I not know about this for so long?.
2) in Layout, under "Object Properties, use the image as a clip map.
I am going to try that.
Looks good. I need to have a closer look to see if it is what i need.
Thanks for your help!
Hector:
One thing to keep in mind about using Clip maps - they're object based. So if you need to clip only a part of an object, then:
1) use a UV map for the area to be clipped. OR
2) place the area to be clipped to another layer and parent that layer to the base layer. OR
3) create a completely separate object and parent that to the base object.
I usually use option #2 as it's more in my workflow routine but use whichever suits you and your project best.
