steveblake Posted July 27, 2006 Share Posted July 27, 2006 I've been toying around with Vray demo the last few days and i'm finding it quite strange. Each time I do a render (even from within the Vray Scene Dialog panel) the settings I have adjusted flick back to defaults. Quite annoying. Am I doing something wrong?? I'm also finding the whole process actually quite slow. I know we're dealing with lots of data being processed here, but I'm used to seeing slightly faster feedback - guess I'm spoilt by having used Fprime for the last few months. Regardless - I'm determined to get going with Vray, does it get any easier once you've used it for a bit? Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted July 27, 2006 Share Posted July 27, 2006 i thought it was each time you saved it flipped back to default settings, but either way, an easy way to test settings without having to wright everything down, and re-enter it each time is to use the presets on the system rollout tab. create your settings, then save them as a preset. Link to comment Share on other sites More sharing options...
manta Posted July 27, 2006 Share Posted July 27, 2006 Its probably the autobak function causing this, it used to do that with the dreamscape demo... Link to comment Share on other sites More sharing options...
steveblake Posted July 27, 2006 Author Share Posted July 27, 2006 ...many thanks for the tips guys - that was it. It's all slowly making sense! Link to comment Share on other sites More sharing options...
steveblake Posted July 28, 2006 Author Share Posted July 28, 2006 I'm confused again. Turning off autobak function *did* help, but I'm finding that when I 'Save Preset' (not saving the scene file at all) - the defaults flip back and then that preset is saved without any new settings at all. Perhaps this is a limitation of the demo? Link to comment Share on other sites More sharing options...
steveblake Posted August 3, 2006 Author Share Posted August 3, 2006 sorry to go on and on about this, but can anyone shed some light? (pun intended) Still having problems saving presets - When i do it doesn't save anything Ive just set up, just the defaults. Then the render panel gets reset again too.. be nice not to have to re-input my settings everytime I upadate, save or reopen the scene... Link to comment Share on other sites More sharing options...
