Vray light saved maps???
jtiscareno
OK, this is sort of urgent 'cause I am right in the middle of finishing an animation. So if some ones knows please let me know, thanks in advance.
The questions is, I am going to precalculate the lightcache map and then the IR map and save both of them to be used for final animation so it is a bit faster. I know that this can not be done thru backburner beacuse it has to be all done from one machine to save as one light file, but... would it work if I can send the lightcache or IR map file to one predetermined machine? It is thru backburner but it is only going to one server...
The reason is that the small 4 machine render farm we have here is very good, those machines are twice as fast as mine so the 1/2 time is sweeeet. I would of couse check the save at render end to have a name and file location ready for the light file.
Any comments.... the vray chaos forum is down :(
