JamesTaylor Posted July 30, 2006 Share Posted July 30, 2006 is it possible to create custom style for objects such as windows or doors that can be stored as a library item etc. i'm not advanced user of revit, but just looking into its potential at the moment for modelling..... i do a lot of residential work for housing developers who use many standard components and i'm finding autocad to be very repetitive for the task, equally i imagine its quite slow in comparison to a parametric modeller used well. your thoughts would be useful along with any good links etc Thanks James Link to comment Share on other sites More sharing options...
Arnel Posted July 31, 2006 Share Posted July 31, 2006 Yes you can do customized doors, windows etc and save it into your library. You can make it also as parametric as you want e.i. different size, materials, and so on. Building a library of your customized objects and selectively saving it into your project tamplate will save you tons of time and be very productive. Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 1, 2006 Author Share Posted August 1, 2006 Thanks Arnel, i've started working through some tutorials, it seems as if it'd be very userfriendly and efficent once a user gets to grips with it and has a libruary set up to their needs. Link to comment Share on other sites More sharing options...
Arnel Posted August 1, 2006 Share Posted August 1, 2006 You can download also some customized families at http://www.revitcity.com or at autodesk web library. To access autodesk web library when you open revit and try to load a family there is a button at the top right of the family dialog box "web library" and if you press that it will open the autodesk revit library web site. Hope this helps. Link to comment Share on other sites More sharing options...
JamesTaylor Posted August 2, 2006 Author Share Posted August 2, 2006 Cheers Arnel i'll check them out also i've posted a new thread on it but is there a way to create custom wall types that can be saved for use across all projects etc? tried the help files but not turned anything up? Cheers Link to comment Share on other sites More sharing options...
