Please Help! about smooth surface
omo
thank you very much J.R.
i am try weld, but it 's seem a little more better
but it 's still not smooth enough
I 'm upload my file
hope someone know how to make more smooth
Thank you for help
This is a very good site and many kind people here
wireframe looks good in editable poly but if you look in editable mesh theres a few spots you can see where the wireframe needs work and vertexes around the edges need welding, as far as i can tell your problems in your wireframe, Id try welding all those extra verts then apply a mesh smooth modifier to get what your looking for, poly count will go up a bit, but should be worth it to smooth everything out.
William,
You're right about welding the vertices, but the Mesh Smooth modifier will change the physical structure of model, so it should not be used. The Smooth modifier is the only thing that will fix this particular problem but before it can fix the problem there are numerous vertices that must first be welded (either as an Edit Poly or Edit Mesh).
