lala18 Posted July 31, 2006 Share Posted July 31, 2006 Could anyone advice how to open failing 3ds max file? I’ve done approximately 90% of job, but now I can’t open it. I tried as copy paste the file, but no use. Link to comment Share on other sites More sharing options...
kippu Posted July 31, 2006 Share Posted July 31, 2006 can you merge it ? Link to comment Share on other sites More sharing options...
Paul Twyman Posted July 31, 2006 Share Posted July 31, 2006 Yeah try merging objects from the scene into a brand new drawing. If you do it one by one you will probably find that it's one object causing all your problems. Had this a few times, I always try to save my scenes with different names after every major change aswell this way you've always got something to fall back on. Link to comment Share on other sites More sharing options...
plastic Posted July 31, 2006 Share Posted July 31, 2006 if it's damaged, look for backup files in the 3dsmax\autoback folder. Link to comment Share on other sites More sharing options...
lala18 Posted August 2, 2006 Author Share Posted August 2, 2006 Hi. Thank to all. I’d already used these methods, but no use. It isn’t possible to merge too. Back up file absent 2. Link to comment Share on other sites More sharing options...
kippu Posted August 2, 2006 Share Posted August 2, 2006 too bad ...but this has happened to me a couple of times after which i always now save files in couples or triples ..just in case of stuff like these.... sorry zhala.... shit happens Link to comment Share on other sites More sharing options...
lala18 Posted August 6, 2006 Author Share Posted August 6, 2006 Thx. Link to comment Share on other sites More sharing options...
teapot Posted August 14, 2006 Share Posted August 14, 2006 Hi. I am trying to open a max file that was done by someone else. I got the following error messages. I tried merging but didnt work. Can anyone help me on this? Thanks Link to comment Share on other sites More sharing options...
ipdesigner Posted August 14, 2006 Share Posted August 14, 2006 Hi. I am trying to open a max file that was done by someone else. I got the following error messages. I tried merging but didnt work. Can anyone help me on this? Thanks *what's the erros by the way?, you should post more info about it..sometimes this happens if you merge a higer version to a lower one:) Link to comment Share on other sites More sharing options...
Paul Twyman Posted August 14, 2006 Share Posted August 14, 2006 Hi, Yeah i think it's because the file has been created with an older version than your own. I think probably one of the newer shaders in this case. Possibly a Mental Ray material. Link to comment Share on other sites More sharing options...
Paul Twyman Posted August 14, 2006 Share Posted August 14, 2006 sorry meant newer version than your own Link to comment Share on other sites More sharing options...
teapot Posted August 18, 2006 Share Posted August 18, 2006 Yeah I also suspected it has something to do with version compatibility. Just wanted to check if others have encountered same problem. Thanks for the replies. Link to comment Share on other sites More sharing options...
